Friday,05,September,2025,04:21:48:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.0.3
Data version: 20250301 DS365.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZJH149128 License Plate: VO99XF
Mileage: 4240km-2634mi Repair Order: 1
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 56 61 69
VIN: WV2ZZZ7HZJH149128 Mileage: 4240km-2634miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KH HW: 04L 907 445
Component: R4 2.0l TDI H02 5952
Revision: 23002001
Coding: 0025401C433401080000
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KH 004012
ROD: EV_ECM20TDI03004L906056KF.rod
VCID: 7DF14CF3ECF16773AB-8028
VINID: 9E60AAAAA1D8A9A6011090422083FCFC52
11 Faults Found:
13174 - Mass Air Flow Sensor (G70)
P0103 00 [00100000] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154183 km
Date: 2082.01.12
Time: 00:00:25
Engine speed: 125.50 /min
Normed load value: 100.0 %
Vehicle speed: 0 km/h
Coolant temperature: 54 °C
Intake air temperature: 7 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 10.109 V
Unlearning counter according OBD: 31
Mass airflow sensor 1 bank 1 airflow: raw value: 268.8 mg/stroke
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -0.35 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 1.231 bar
Absolute intake pressure: 98 kPa abs
Mean injection quantity: 24 mg/stroke
13184 - Engine Speed Sensor (G28)
P0322 00 [01100000] - No Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154182 km
Date: 2082.01.11
Time: 11:41:58
Engine speed: 811.50 /min
Normed load value: 14.9 %
Coolant temperature: 76 °C
Intake air temperature: 33 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.468 V
P_L_Aps_learning_done_nvv: On
HWI_Aps_cam_index: 3
P_L_Aps_no_sync_speed: 814.75 /min
P_L_Aps_camshaft_drift_angle-Camshaft target wheel drift angle: 0.73 °
P_L_Aps_crank_event_num: 06
P_L_Aps_mode-APS working mode: P_L_APS_NORMAL
P_L_Aps_cam_edge_learn_done: 00
P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_CAM_NOCAM
P_L_Aps_sync_tasks_enabled: On
27292 - Crankshaft Position Sensor (G28)
P0335 00 [01100000] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154494 km
Date: 2082.01.18
Time: 07:42:29
Engine speed: 1035.00 /min
Normed load value: 0.0 %
Vehicle speed: 71 km/h
Coolant temperature: 86 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.562 V
Unlearning counter according OBD: 39
HWI_Aps_cam_index: 1
HWI_Aps_gap_period_detected: OFF
P_L_Aps_crank_event_num: 5D
IN_Injection_speed: 1035.00 /min
32111 - Voltage Supply for Particulate Sensor
P24D0 00 [00100000] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 154183 km
Date: 2082.01.12
Time: 16:01:34
Engine speed: 0.00 /min
Intake air temperature: 27 °C
Voltage terminal 30: 11.257 V
Air mass at air mass meter 1: 0.0 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 1.36 %
Charge air pressure: specified value: 0.000 bar
Absolute intake pressure: 100 kPa abs
Mean injection quantity: 31 mg/stroke
Index of current engine mode: 0
Index of next requested engine mode: 0
Index of engine target mode: 0
27277 - System Voltage
P0562 00 [00100000] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 0 km
Date: 2000.01.00
Time: 00:00:00
Coolant temperature: 25 °C
Voltage terminal 30: 14.265 V
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.78 %
Absolute intake pressure: 99 kPa abs
Mean injection quantity: 33 mg/stroke
Index of current engine mode: 10
Index of next requested engine mode: 10
Index of engine target mode: 10
30540 - Throttle Position Sensor (G69)
P0121 00 [00100000] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.01.00
Time: 00:00:00
Coolant temperature: 23 °C
Intake air temperature: 13 °C
Voltage terminal 30: 13.421 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: 4.46 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 100.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.55 %
Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 4.740 V
25126 - Implausible Data Received from ESP Control Module
U0416 00 [00100000] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 154183 km
Date: 2082.01.12
Time: 16:01:37
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status: passive
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
27202 - Sensor Reference Voltage A
P0641 00 [00100000] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 154183 km
Date: 2082.01.12
Time: 00:00:19
Coolant temperature: 55 °C
Intake air temperature: 6 °C
Voltage terminal 30: 4.156 V
Engine status: Engine start
Engine running time-Pressure BIN10 bar: 0 s
Control Module temperature: 29.5 °C
ESM_Battery_voltage-Voltage: 4.15 V
Low battery mode active-Bool type: No
ESM_Vext_raw-ESM_sensor_voltage: 3.2891 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: active
Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
Starter control: terminal 50 feedback-Terminal 50 via cable: active
Starter control: terminal 50 feedback-Starter relay: active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: active
Starter control: terminal 50 feedback: 62
Starter control: shut-off conditions 1-Immobilizer: not active
Starter control: shut-off conditions 1-Starter shift malfunction: not active
Starter control: shut-off conditions 1-Speed: not active
Starter control: shut-off conditions 1-Drivetrain: not active
Starter control: shut-off conditions 1-RPM aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration: not active
Starter control: shut-off conditions 1-Engag. duration aborted starts: not active
Starter control: shut-off conditions 1-Engag. duration panic start: not active
Starter control: shut-off conditions 1-new errors: not active
Starter control: shut-off conditions 1-manual start/error: not active
Starter control: shut-off conditions 1-ignition: not active
Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction: not active
Starter control: shut-off conditions 1-Direct start function: not active
Starter control: shut-off conditions 1-Engag. duration defrost.: not active
Starter control: shut-off conditions 1: 0
27200 - Sensor Reference Voltage B
P0651 00 [00100000] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 154183 km
Date: 2082.01.12
Time: 00:00:19
27198 - Sensor Reference Voltage C
P0697 00 [00100000] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 154183 km
Date: 2082.01.12
Time: 00:00:19
Voltage terminal 30: 4.492 V
ESM_Battery_voltage-Voltage: 4.47 V
27196 - Sensor Reference Voltage "D"
P06A3 00 [00100000] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 154183 km
Date: 2082.01.12
Time: 00:00:19
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01 CVN: A5BFDF55
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 3D718CF3AC71A773EB-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 60678000001522
Coding: 347E4098256686872C760278A48A6193780000
VCID: 3F8DF6FBA67DB563F9-806A
2 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 101
Mileage: 154183 km
Date: 2025.08.30.
Time: 16:01:37
0397 - TPMS Warning
C102D F0 [10001001] - Pressure Loss
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 23
Mileage: 150586 km
Date: 2025.07.31.
Time: 14:22:20
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 17021813471854
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C6BB2-802A
1 Fault Found:
136194 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 154183 km
Date: 2025.08.30.
Time: 00:12:56
Voltage terminal 15: 0.00 V
Voltage terminal 30: 8.85 V
Terminal 15 status: OFF
Entprellzeit: 90000 ms
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 R HW: 7E0 907 040 R
Component: ClimatronicT5 H04 0613
Revision: 00001K04
Coding: 0004000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN75.rod
VCID: 326BAFCF652F680B06-8066
Slave 1:
Subsystem 1 - Part No SW: 7E0 907 049 HW: 7E0 907 049
Component: Heckbedienung H04 0042
Serial number: PAG00205031800010002
1 Fault Found:
9672979 - Heated Seat; Front Right
B1399 13 [00001001] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 150859 km
Date: 2025.08.06.
Time: 08:11:21
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 067181409
Coding: 62F879384AE1041201280F746CAB9EF40F84690F60C46960330400A30840
Shop #: WSC 02762 534 719508
VCID: 2B55B2AB4A0539C345-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 170122 05 52 0106
Coding: 008F77
Subsystem 2 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 004 0653
Serial number: KU0KU008031880673404
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 004 0653
Serial number: KU0KU008031880672041
Coding: 1400A0
Subsystem 4 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180000257440058093
Coding: B0FFFF
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 101
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 101
Time Indication: 0
04194 - Vehicle Status with Under-Voltage
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 102
Mileage: 154182 km
Time Indication: 0
Date: 2020.01.21.
Time: 19:19:27
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261802602387
Coding: 31810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71E960C3A0A913133F-8024
1 Fault Found:
13893632 - Function Restricted due to Insufficient Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 154183 km
Date: 2025.08.30.
Time: 16:01:32
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 K HW: 7E0 959 655 K
Component: VW10Airbag01R 010 0018
Revision: -------- Serial number: 003EM000GNPH Dataset Number: 7E0003V____ 0908
Coding: 000000000000000000000000000000003152
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3E738BFFA177BC6BF2-806A
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB401G5BP7ALGVQ
Crash sensor for side airbag: passenger side:
Serial number: 3505ZRB401I5BP7A9HS6
1 Fault Found:
9682162 - Multiple collision brake
B13BC F2 [00001000] - No function
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 154183 km
Date: 2025.08.30.
Time: 00:00:03
Address 17: Instruments (J28) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 140F010300
Shop #: WSC 02761 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 397998E3B8599B53C7-806C
Slave 1:
1 Fault Found:
13635840 - Supply voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 0 km
Date: 2025.08.30.
Time: 00:12:52
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B55B2AB420539C345-807E
1 Fault Found:
0375 - Function Restricted due to Insufficient Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 24
Reset counter: 101
Mileage: 154182 km
Parking heater: operating condition: OFF
71
Coolant temperature of parking heater: 0 °C
Coolant temperature: -48 °C
Engine running status: not detected
Fuel level: 0 l
Heating performance: 0 W
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042207
VCID: 68DF0DA79B73D2DB68-803C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 150586 km
Time Indication: 0
Date: 2019.12.22.
Time: 14:22:26
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6ADB77AF8D7FE0CB7E-803E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 330B1A73
Shop #: WSC 09999 999 999999
VCID: 68DF0DA79B73D2DB68-FFFE
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000473069207
Coding: 410D000103000000
Shop #: WSC 02762 790 00000
VCID: 326BAFCF6D2F680B06-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 101
Time Indication: 0
End-------------------------(Elapsed Time: 03:47)--------------------------
------------------------------24 Faults Found------------------------------
