powerbungalow
Hi. I have a Cetek D250SA and a Sargent distribution board in my T6 (installed by others). I am concerned that the system has been wired wrong. The small red wire for the smart alternator connection is not in use! There is a constant 12v at the Alternator input terminal on the unit and also at the service battery outlet terminal (when the van is parked up). The green light on the unit flashes occasionally but the system does work and the output to the service battery with engine running is 14.7v
I understood it that the CTek unit was meant to be OFF when the ignition was off? Is there a different way to wire this if using a Sargent DB?
