jimjones235
I'm replacing the internal lights in the rear with LED downlighters and want to put in a 3 way switch. I've got the courtesy lights with 3 wires (+ve, perm -ve and timed -ve). The way I'd go about this is connect +ve on lights to +ve wire, -ve on the lights to common on switch and perm -ve and timed -ve to the two switched connectors... all good... but the switches I've got suggest something totally different, which I think is confused by the fact they have an LED in them.
Here is diagram:
I guess the switch is designed to run off the +ve not negative, now, a switch is a switch so probably shouldn't matter, but in this case as it's running an internal LED it's left me scratching my head.. It's compounded by being a DPDT switch (so two circuits). Any suggestions for how to wire this up?
As an aside I'm bemused as to why they switch the -ve - always thought better to switch the +ve.....
Here is diagram:
