"comfort" handsfree system setup retrofit
gerry
France
VCDS User
hello,
on my vw california I installed the comfort system for the telephone
but I did not modify the coding on the car radio if someone has this system can give me the coding of the car radio thank you gerry
A VCDS Auto-Scan would be helpful.
I don't have the system but could this one be related?
Can you please post your complete Autoscan?
Reactions: mmi
my last scan
Thursday,24,December,2020,16:44:03:43195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV1ZZZ7HZHH006144 License Plate: 24/12/20
Mileage: 60890km-37835mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 5F 61 0B
VIN: WV1ZZZ7HZHH006144 Mileage: 60890km-37835miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8440
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005986D9CA8988BB732-8054
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41346000000190
Coding: 557E409825628484AA76027AA48621D6380000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4525F7F737434A8-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20051613470083
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F821B07DFE4B01E-802A
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 149160058
Coding: 7AA839B84A21209201280F746CEB96D48FA0604F60CE6960320400230800
Shop #: WSC 02737 534 140351
VCID: 2A0D04711CF5A2EB0D6-807E
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 250516 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 N HW: 7E0 959 801 N Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0654
Serial number: KU0KU002051881221365
Coding: 0400A1
Subsystem 3 - Part No SW: 7E0 959 802 R HW: 7E0 959 802 R Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 005 0654
Serial number: KU0KU027041881171826
Coding: 1400A1
Subsystem 4 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 29160000851490066175
Coding: A4FFFF
1 Fault Found:
03021 - Local databus 3
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 60895 km
Time Indication: 0
Date: 2020.12.24
Time: 11:13:00
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231735500928
Coding: 108009
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD31DF12391338CC-8024
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag020 H08 0018
Revision: -------- Serial number: 003V3000YUBQ
Coding: 000000000000000000000000000000003230
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D3431ECD5126B7D6-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1104
Coding: 140B010100
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 392F2B3DE9D3197374C-806C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042205
VCID: 6889BE79C27950FBDB2-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 010100E200000000000000
Shop #: WSC 02748 790 50316
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D070F6D2D9BB5D3E84-8078
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A8DC471DCF562EBCD6-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 H HW: 1K8 035 150 H
Component: MU-E--ER 055 7067
Serial number: 25041600010707
Coding: 065700003C00000041110001800100031F0000C40000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2A0D04711C75A2EB0D6-807E
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001605200165
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.2V)-----------
Address 08: DTCs cleared
