Caster out of spec
muddyboots
Hi all.
Recently took my new-to-me van for a Hunter alignment.
It's a 2021 T6.1 T32 199/204 4motion Kombi.
Initially they set it up to generic medium load, then I read some posts on here and took it back - so it's now done to "no load", and to the correct suspension code off the VIN sticker.
Everything is nicely in spec - except caster. This is about 3 degrees out, and is equally out on both sides.
Any ideas what might cause this?
I gather if the subframe was rotated, caster would be out, but by opposite amounts, so am guessing it's not that.
Generally drives fine, doesn't pull - only thing I noticed is under hard acceleration, the steering does tug side to side a lot.
Thoughts?
