Camperglass window not flush with van.
Yours look different to mine. I fitted mine the other way round with the larger protrusion (the bit with the sticky strip) on the outside face of the window. To my mind this gives better protection to the edge if the glass. Can’t remember reading any instructions 🤷‍♂️. So perhaps I went typical ‘Engineer’ and just ignored them or fitted how I thought it should be. Not saying I’m right you’re wrong. Now I’m curious what others have done.
As an engineer myself I also ignored instructions but just did the opposite to you ! 😂
Either way looks okay, my thoughts were just that I was closing the gap that little bit so it didn’t look as bad but I can see how it can be done both ways
Having removed my OEM rubber to fit the fake quarter panel I can confirm that sticker section is on the outside of the window.
I was doing a bit of digging as I wasn’t entirely sure after you pointed that out, found this on Camperglass looks to me like it’s on the back edge behind the glass but then you may see it differently than how I’m looking at it.
Just used these which were perfect and cheap.
I just found this on AliExpress:
£2.30 | SEAMETAL Car Door Edge Seal Strip 2/5/10m U-Shape Auto Door Protector Guard Trim Anti-Scratch Weather Strip Decoration Stickers
£3.26 | 6M/1Roll Window Dustproof Soundproof Bedroom Door Weather Sealing Strip 10*6mm Self Adhesive Anti-Collision Sound Insulation
I asked THQ and they said the sticky should be on the inside as @Creaser has them but I thought I’d seen them on the outside as @Kev.O. So I tracked down a factory Kombi at our local deal and photographed it, they are definitely on the outside of the window. So confused which way they should be installed now!
Why would it be sticky on the outside? To what aim?
If I understand your ?? correctly, )no egg sucking intended). it refers to the sticky strip (which is on the inside/internal of the rubber ‘U’ channel being on attached to the outside face of the window. This results in the wider rubber portion being on the front face of the window. Stick it on the back, and the smaller section of rubber is on the outside. To my mind much better protection is offered to the exposed edge of the glass if the larger bit of rubber is on the outside. (And it’s much easier to install). Ultimately it’s based on aesthetic preference of the installer. 🤷‍♂️
Makes sense. When I saw people mentioning "sticky on the outside" I presumed the outside. 😂 My thinking was if it was sticky on the outside then that side should go against the van body to pull the gap in. Stupid boy.
I understand you’ve opted more for protection by sticking it on the outside, whereas I was just trying to close the gap between my van and the window on mine as it was bugging me so it’s each to their own really. Mystery continues😂
Will you not have an awkward coloured gap between your windows, or are you reinstating the rubber ?
I purchased a trim part which sticks to the back of the existing window and hides the colour gap you make reference to. With the original rubber part it doesn’t look at smooth IMO and it’s not what the caravelle has either
Has anyone got any photos of the other end of the glass where it curves to meet the body? I had some fitted by a company, but on one side the bottom sticks out. They’re claiming it’s due to the window’s tolerance and that it won’t sit flush with the curve — but the other side is perfectly fine. I’m not convinced.
Heres mine.
It wasn't like that at first. I had to jam wood top and bottom against a lamp post while it set to get the gap like that.
Less of an issue that end due to the panel moulding?
C'mon, I've shown mine. Show me yours.
