C Rail Mounting
Fluff34567
Swiss member
Hi,
I ordered an awning and c rail sections from wild earth.
I need to drill holes in the rail. Do you normally reuse the current blanking bolts?
The one I got from funky leisure came with new bolts and washers. Don’t forget to put a bit of silicone or leak sealer on the threads
Don't hold back on the sealant. You need to get it right around the bolt as it goes through the hole in the roof, covering more than just the threads.
Pete
