Big splash guards vrs. little splash guards
moomin-j
Get busy living or get busy dying.
T6 Legend
To all you brake gurus...
Is there a size difference between the splash covers for the 16” chassis brakes (single piston) vrs the bigger 17” chassis (twin piston)?
I know the disc sizes are different (308mm vrs 340mm)
I believe the different part numbers are:
16” chassis splash covers: 7E0 615 311B & 7E0 615 312B
17” chassis splash covers: 7E0 615 311A & 7E0 615 312A
It’s item 4 on both:
As I'm fitting the bigger brakes but they come without the splash guards and I need to understand if I have to spend more cash!!
I also think i need to replace part number 19, as these can only be used once?
Can anyone help please?
Is there a size difference between the splash covers for the 16” chassis brakes vrs the bigger 17” chassis?
I know the disc sizes are different (340mm vrs 308mm)
View attachment 99648 View attachment 99649
I also think i need to replace part number 20, as these can only be used once?
Are you doing the REVO brake brake kit :whistle:
Nope - money won't stretch that far - it's just the standard Vw bigger brake kit, removed from a delivery mileage, big engine 6.1 T32
I would if I could, but I can't so I won't!!
The splash guards aren’t a requirement for an MOT but I would advise you fit them as it will limit the amount of brake crud spread about and they will protect the discs.
The two bolts normally come with a set of brake pads, yes they should be replaced and the old ones binned, not an area for saving money.
Blimey - how much are these bad boys.
Someone's got big pockets to afford these...
Maybe I would, if I was the MD of a profitable wood yard @Eli :thumbsup:
Reactions: Eli
