Battery registration
Can you register them with the Carista I’ve had a search and not sure if it can only do bmw?
I can't be that important, our T6 which we bought new wasn't correctly registered from the factory. I only found out when I changed the battery and went to register the new one with VCDS and compared the settings.
Why am I not getting battery registration on the carista app I've just downloaded the updated beta version and still not getting battery registration coming up in the service menu.
My Carista doesn't seem to do anything. I connect it up, have a twiddle,mit appewrs to read the systems and recognise them, but whennIntry to alter any setting it tells me it can't do anything to the van. It's probably me, but it does seem a right POS.
My van had a new battery prior to sale, and I did ask about battery registration as I'd come up against this before in a Peugeot I once owned. They told me not to worry, the van will do its own adaption and within a few hundred miles will adjust charging rates etc accordingly, which to be fair it seems to have done.
Unfortunately (at least for me - don't know if it is the same for everyone else) for the last month or so, you need your bonnet open to do or look at anything.
I did contact them about this but they said it was down to VW. Having not had any updates from VW in that period, can't see how, but it is out of my hands.
The carista has done everything I've ask it to do, like code my new thq headlights and turn the parking sensors down. I just abit confused why I've had no battery registration option come up in the service menu. I've contacted carista and they sent a upgrade to me but still no joy.
Just to clarify - the bonnet doesn't need to be fully open - just pull the bonnet catch from inside - that is enough to activate the connection.
Remember to close the damned thing afterwards - yes, you will have to get out of the driver's seat to do that unless you have a willing serf.
To make everything work.
Prior to the bonnet being open it'd see systems, but give me an error message when I tried to change the settings.
By battery registration, do you mean coding the battery monitor having replaced the battery?
