Battery light on, not charging
  • Thread starter Thread starter mvw
  • Start date Start date
mvw
Hi,
Hopefully someone can help, I've just got back from a week away in the Van (T6 2017) and when I got to within a few miles of the house the red battery light came on. I turned everything off I could and got home no problems. When I put a multimeter on the starter battery (when the car was running) I can see it's not charging it was at something like 11.9v. I did a scan (only have Carly) and it has a 02252 fault. I can see the aux belt running and I had a new alternator fitted a few months ago. I've read as many posts as I can, I didn't have any start/stop warnings on the dash and I've pulled the wiring open from the alternator to the bottom of the sump and there's no obvious wire breaks.
When testing I can see that if I enable the leisure side of the electrics to work, the leisure battery is charging when the car is running (Stirling DC-DC charger), does that mean it can see 14v at the starter battery? It's a Fogstar Drift so I can see it charging in the app.
My starter battery has always been sluggish on startup and never sits at 12.6v (mostly 12.0v) so I was going to buy a new battery anyway. But even if the battery is bad, should I see it trying to charge when the car is running? At the moment my local garage is just a bit to far to risk driving there with a dodgy battery that isn't charging. Plus I do have that 02252 fault
I've also cleaned up the battery terminals and they all look fine.
Any help on what I could test myself with a multimeter would be much appreciated.
Lee
That fault has often been a broken wire.
You will not see a high voltage from the alternator at engine idle speeds as the smart alternator will only supply higher voltage when there is a demand on the supply. Try turning the headlights on and watching the voltage.
Thanks, typically one thread I didn't read! I think splicing a wire in to test could be a way forward, but will probably leave for a professional :-)
Check the engine earth strap / connections near the free end engine mount.
If in doubt put a jump lead between the engine and the chassis at paint free points
Also . How old is the battery.
3-5years is expected... Any older and it's due for replacement.
I just put a jump lead from the battery earth to the engine block and it still wont charge, but I will clean that earth strap up as well. Thank you
I think the battery was replaced when the van was converted in 2020, so it's definitely due a new battery. I think I'll order one anyway as even if it's not the problem, it's due a replacement.
The reason I'm not 100% sure on a break in the LINBUS wire was that most posts say that it defaults to charging when you blip the throttle and that you get a stop/start warning, neither of which happen to me. That's not say it isn't that, but I think a competent mechanic could test the continuity of that wire without splicing into it. So I think I'll order a new battery for tomorrow and then book it in. Now it's charged again (actually used my EC-155 to charge it), it doesn't seem to be losing much voltage while idling so I think I can risk a 5 min drive to my local garage 😬
02252 is a generic code - need to read the subcode - the usual one is about communication via LINbus
02252 - 004 - Generator - No Signal/Communication
02252 - 012 - Generator - Electrical Fault in Circuit
etc.
DC-DC charger can take in lower voltage which its converted to higher voltage for charging.
Aux belt seems to be ok and my leisure battery seems to be charging
your leisure battery will be charging, it will be sucking the life out of the starter until the starter battery voltage drops to the cut off voltage.
I thought my 5 year old Varta starter battery was in good health, no problem cranking and solar keeping it topped up.
It was only when I was loading my leisure battery up with winter use that I realised the alternator was stuffing amps into what must have been a starter battery with an internal short.
Once the starter battery was replaced the leisure battery was much healthier.
Thanks for this info, if/when I drive it to the garage I'll make sure I isolate the leisure battery so it's not draining the starter
etc.
Thank you, this is all really helping me understand what's going on
Just to close this out, after the advice I got on here I was confident enough to drive it to the local garage and it turned out to be a faulty alternator. So the one that was put in about 3 months ago failed. They put a new one in FOC
Very unusual, any idea how it failed?
When I'm back at home I'll look at the original invoice. I think it was Bosch
