paul stevenson
If I have my van hooked up to EHU in my garage will it charge both batteries, main and leisure.
Are you sure the charger doesn’t go to the leisure? If you are at a campsite say for 3 days and running the fridge etc your leisure battery could go flat as the B2B only works when the van is moving, that’s why the mains charger normally charges the leisure . The B2B is for when EHU isn’t available so that it tops the leisure up whilst drivingThis is how, I think, mine works - EHU goes to a charger in the van which is connected to the vehicle battery.
The vehicle battery has a BTB charger connected to the leisure battery.
So.......the charger charges the vehicle battery which in turn charges the leisure battery.
We have a Sterling B2B which seems to work on a timer system so it works when both moving and parked.Are you sure the charger doesn’t go to the leisure? If you are at a campsite say for 3 days and running the fridge etc your leisure battery could go flat as the B2B only works when the van is moving
I’ll need to do a bit of reading up on my B2B then. I thought they only passed power to the leisure battery if the van was moving, otherwise the B2B could completely drain the starter battery if it kept passing power to the leisure whilst parkedWe have a Sterling B2B which seems to work on a timer system so it works when both moving and parked.
I believe that most do just as you say, I think it is only the Sterling that has a different system I think it works on voltages and a timer rather than a switch.I’ll need to do a bit of reading up on my B2B then. I thought they only passed power to the leisure battery if the van was moving, otherwise the B2B could completely drain the starter battery if it kept passing power to the leisure whilst parked
I have a Sargent box in the van and can send the charge to either the vehicle or leisure battery, it was only when the Sterling B2B charger was retro installed to get over the 80% charge issue that this charging of both batteries at the same time when on EHU was discovered.Thanks @Nigel W , Hadn’t realised that
Sorry, I'm not an auto electrician so really don't know. I told my installer what I wanted to achieve, and they set about determining how to do it with various relays and components. You could always call them; ALM Electrical Solutions in Redditch 01527 521600, ask for Kevin.@DaveyB interested in this swap over from leisure to starter when leisure is full. What’s involved in setting that up?
Thanks Davey, I’ve actually got a good mains trickle charger in the garage that I used to use on the bike, I’ll probably just start hooking that up to the starter battery when the van is not in use until I work out if there’s a simpler way. My EHU point is beside my battery anywaySorry, I'm not an auto electrician so really don't know. I told my installer what I wanted to achieve, and they set about determining how to do it with various relays and components. You could always call them; ALM Electrical Solutions in Redditch 01527 521600, ask for Kevin.
Sounds like a plan.Thanks Davey, I’ve actually got a good mains trickle charger in the garage that I used to use on the bike, I’ll probably just start hooking that up to the starter battery when the van is not in use until I work out if there’s a simpler way. My EHU point is beside my battery anyway
