Are these the correct wheel bolts?
Assume the black longer ones are the new ones? if so, length alone would worry me and can’t see how these would be right.
Fitting spacers. 15mm spacers so got longer bolts.
I’ve just fitted the wheel and they seem fine, was worries about the cone shape.
Really? Any links as to where I can get 50mm length bolts for oem wheels?
You need radius seat bolts assuming that the spacers are being used with VW original wheels.
Don’t use the tapered seat bolts in your picture, they run a very high risk of coming loose as there will only be a tiny portion of the seat in contact with the wheel.
2 options here, but they’re both silver. You can buy some black plastic caps, which will stay black longer than a black wheel bolt anyway.
Gebildet 20pcs 19mm Wheel Nut Cap,Wheel Bolt Nut Caps Covers,Hexagonal Tire Nut Covers with Removal Tool Set for Cars(Black) https://amzn.eu/d/0ZfTXl5
Thanks Chris. See you Tuesday for the headlight install
Out of the two options in my previous post, I would go with the OEM style ones. They have a 19mm hex so will work with your OEM wheel brace. The others have a 17mm hex, so you would need an alternative to remove them in the event of a flat.
