Thanks for your reply
The Bear78.
I have a couple of remarks/additional questions;
Quote;
The Dc-Dc charger should be connected directly to the leisure battery negative anyway rather than through the chassis. Unquote.
If I read correctly (think on Dellmassive's page) nothing (including DC-DC charger) should be attached at Start Batt. -Ve directly to avoid draining by bypassing its shunt (on all EUR6 models, which is what I have). In that same tread it was recommended to attach to earth point 34 under the seat.
Quote;
There is no need to use the chassis if directly connected to the battery. Unquote.
That would be good news for me. When looking at the Victron wiring diagrams they seem to do it but then again might have loads connected to chassis as well (not shown in their diagrams).
Quote;
AC earth should connect to the chassis for a safe route back to earth in the event of a short. Unquote.
In my diagram they go to the earth point above the wheel arch. I wasn't sure if I should pick a different earth point then the one where DC-DC -Ve is attached to (under seat). Still not sure if in the event of a short on the inverter it would actually run back to the earth as I would then not be connected to any real ground having rubber wheels isolating the whole thing... I know the best way is attach a galvanic isolator but was hoping to avoid this as "overkill".
My biggest concern is to fry 12V systems in the event of of a short because the ground not being a real ground... but hopefully my MCB should avoid this.
So; Could I mix AC Ground + DC Negative on the same earth point? Guess it doesn't matter in the end?
Quote;
Ideally you'll have a double pole MCB in the AC system as campsite hookup polarity cannot be guaranteed. Unquote.
Until a couple of weeks ago I didn't really know anything about electricity but I gather that the below would fulfil this requirement?
Legrand
TX³ 2P 30mA 63A Type A
Another concern I had was the wiring between the Blue Smart charger and the Orion-Tr DC-DC. This wiring (+ & -) is meant to charge the start battery (through the wiring of the DC-DC to avoid a second cable run forward) but by doing so would I actually ground the whole system to the chassis over this undersized wire? Should I skip the Negative lead and only connect the Positive? Something not right...
Then another question mark; Running my wiring from MPPT to solar panels; From the solar panels wires go to a junction box near rear lights, from there on to breaker and then to MPPT. Should I include the length of the (pre installed) solar panel wires to the junction box to determine the wire size between MPPT and junction box?
And finally; The Positive input in DC-DC charger (from start battery) is currently sized as 10mm2. Cable run is 3,5m, 30Amp, so at 20*C gives a voltage drop of 3%. Just acceptable or HAVE TO increase to 16mm2 as recommended in manual? To run the wire seems a lot more difficult at 16mm2. And additionally; I would have to redo it as I already pulled a 10mm2...
I really appreciate your input! A little more daunting then I had envisioned...
Cheers!!
