Another Spacer Question - 15mm
racT6bus
Hi there,
Looking to get some spacers for my rear wheels to better align with the front and to improve the stance. I have a set of Navic MAC Ats with Michelin CC SUV 235/65/17 tyres (lowered on ST-X coilovers). Can anyone recommend a set of hub centric 15mm spacers? And what bolts/lock nuts would I need for them?
Any help would be great please.
I used Wheel Parts Direct. Their spacers are excellent quality for the price and delivery was next day.
Bolts need to be 15mm longer (or depth of the spacer if different) than your current ones with the same shaped head. I went with 50mm Tapered and matching lock nuts. Yours may be different though.
15mm on the rear works great at bringing them out in line with the front.
Thanks very much that's great, will take a look today.
Also PCD parts, they make their own and have a good on line order system .....
I've double checked with Navis and the Mac-ATs use a "radius" nut as opposed to "tapered" should anyone need to know that! They are also 35mm long so with a 15mm spacer I'll just be getting a 50mm radius nut to replace
I have some 12mm and 21mm spacers available in the for sale section if they are of any interest to you.
Thank you, I did look at them both, but after some measuring 15mm seems to be the optimum to keep in line with the front wheel and not mess with the sliding door.... hopefully!
I have just been looking on their website for 15mm spacers in black, they almost seem too cheap! Are they decent enough to do the job?
