Hi everyone, thought I'd post on here rather than the FB page - always preferred a forum!
Hoping to get some advice on why my alarm keeps going off. It's a highline model, so factory fitted sensors and it seems ok if I turn these off. There's no bugs living in the van but in last few days the tailgate hasn't released properly a couple of times and I've need to manually release it by taking the plug off above the lock inside and pushing the lever in there.
After reading lots on here and other websites, I'm coming to the conclusion the microswitch on the tailgate is duff or at least on it's way out. I've leapt to this as one test I read was to see if the internal lights come on/ go when you open doors. I've checked this and the internal lights don't off when I shut and lock the doors. This might have been happening for a while as I recall them staying on and I ended up leaving the lights in the always off setting.
The van can be locked for 24+ hours before the alarm goes off, or it can go off after a few hours of being locked (with sensors on) so it's quite random.
I've been plagued with electrical problems ever since the van was converted in Jan, the conversion company added new rear speakers in the tailgate but used screws way too long and they pieced the loose speakers wires causing it to ground out and burn my stereo out, plus flatten the battery. I've since added a new stereo and starter battery, but since adding the battery, I've had this alarm issue. VW wouldn't code the new battery in as it didn't have a QR code on there for them they also said they couldn't get any fault codes on why the alarm was going off.
Would appreciate any feedback, the van is going into VW on Thursday as the oil filter they fitted is leaking, so if there's a chance it's the microswitch, I can get them to change that also. Seems howeverI need to tell them the problem rather than let them work it out themselves
