Airco drain or leak
CPL0400390FDP
Hi,
Question related to the airco:
Using it on a normal 23 degrees day. After a 2h ride, parked for 1h and rode again for 30 min. After 2 minutes parking I noticed lots of condens dripping at 2 locations under the Van. 1 drip every 2 seconds.
Is this a normal level of condens, havent noticed it before. My 2019 T6 has 63.200 km - bought it from Volkswagen at 55.800 km last May. No known issues with the airco condition in the cabine, works fine. Drain looks clean - no condens on the windscreen.
Does the airco needs a refill or is there another problem?
Many thanks for assisting!
The aircon drain is located on the engine bay bulkhead on the battery side
It is normal to leave small puddles on the floor after its been running for a while
Dont forget the AC pipes contain refrigerant that is very cold so thats probably condensation on the pipe that will clear when the AC is turned off
Dont think you have anything to worry about
