Additional screen mount for my caravan reverse camera
BRABUS
I have an additional screen that I like to use in my car for the rear/reverse camera on my caravan. My trouble is that I am struggling to find a mount that I can fix temporarily but that will hold the screen below the level of the dash. I don’t want plod pulling me for obscuring the windscreen. The mount I have been using has been a pain in the backside as it is a sucker on the windscreen with a long bendy arm and it always do comes off.
I just wondered if anyone else had found a suitable arm or even a different way to mount a screen.
Cannot provide a link but was considering a multi screen set up atone time and a load of options were available on line. Might need to change wording of search occasionally to home in on exactly what is wanted or needed. Very easy to become distracted by all the possibilities!:)
If you can think of any of the terms you used please as my Google ability is failing me on this one.
Try,
vehicle camera screen
multi screen
vehicle rear view screen
vehicle multi camera
could substitute vehicle with car or even with truck.
Some of the rear-view cameras systems also have multi camera set ups sometime one magically finds a nest with loads of interesting possibilities at other times it is a bit needle in a haystack
Good luck others might have some good ideas or even have a solution lots of stuff on Amazon I recall. Once you see the sort of thing it is then easiest to tailor the search or go back in another direction. It could be a case of the blind leading the blind :rofl::)
Thank you, their mounts look great but I noticed that the one to the left of the gear stick would make the screen be right where the passengers knee is. I am starting to go even more grey LOL
Thanks for the suggestions folks.
For the right hand screen I will be using this in the drivers cup holder
Right hand screen mount
For the centre screen I will be using this down in the center lower cup holder. Have a picture of this one just to show you. I had the screen down low but it will extend and allow you to have it up much higher.
Centre screen mount
