Adding Armreasts To Single Seats.
Epic-Rob
Kiwi member
Is it possible to add armrests to yr std single seat? i can feel the hole where they would fasten trough the fabric.
but i bet its just not a case of buying some and bolting them on...
There is a great video on the forum of how to do it. I got mine from cali campers on ebay. Fitted 1 set in under an hour and yes just bolt on.
Top tip - use heated 22mm copper pipe to burn the holes into the fabric once youve bolted the brackets on.
Ian
PS cannot find the video!!
Was it a 2nd hand item? Cali campers seem to be T4 specialists.
also video not showing - can you direct message me link :)
ok so it seems a google search off forum shows me all i need :)
cheers for info though:)
Just seen your message about fitting arm rests, I did it last year to
My seats and to be honest if I can do it then anyone can!
I used that you tube video and it guides you through really well
Got the arm rests off amozan for my t6 and fitted exactly
As shown on the video
Go for it
