Adaptive cruise control upgrade
Swoop1
Hi anybody know how much it should cost to have adaptive cruise control added to a t6 with cruise on the mfsw and front sensor already fitted please ?
Thanks for any input 👍🏻
Not something we do I'm afraid
Hi
I wonder if anyone can help
I have a t6 transporter 2018 and it has cruise control with steering wheel switches the van aso has front assist and radar fitted.
I changed the steering wheel buttons to include the ACC button.
How do I enable the coding on the van so the ACC will work.
Is it something I can do myself.
Yeah, I looked into this a while back and it’s not as straightforward as you’d hope. It’s definitely not just a coding job unfortunately.
ACC needs quite a bit of extra hardware, not just the radar. Even if your van already has Front Assist, that doesn’t mean it’ll support adaptive cruise without swapping parts and adding wiring. Then there’s coding and calibration on top of that.
From what I’ve seen, people have done it, but it’s pretty involved and not really something you knock out over a weekend unless you really know what you’re doing. Most end up going to a specialist.
Personally, I decided it wasn’t worth the hassle/cost in the end. Standard cruise does the job fine for me, and ACC seems a bit hit and miss in real-world driving anyway.
I can completely understand why the retrofit looks so daunting at first glance, there is a lot of misinformation out there, but I actually have to strongly disagree based on my own experience doing this. It’s definitely not as complicated or expensive as the specialists make it out to be, provided you have the right base spec.
If your van already has Front Assist and standard cruise control on a Multi-Function Steering Wheel (MFSW), the hard work is practically already done for you.
If you already have the MFSW and standard cruise, the wiring is already right where it needs to be. Upgrading the steering controls is quite literally just a plug&play replacement of the MFSW buttons.
You don't need to worry about Component Protection and you can simply buy (or trade in your current sensor for) a patched, plug&play radar unit.
The coding can be done in your driveway with basic enthusiast tools like VCDS or OBDeleven. It just requires a few simple coding adjustments in the ECU and ABS modules to tell the van the system is active.
If you swap your replacement radar onto the existing bracket, the physical alignment remains exactly the same. No additional alignment or expensive calibration is needed.
I'm definitely not going to try and convince you to get ACC if you prefer standard cruise. ACC is really a system designed for people who fully understand its principles of operation and respect its limitations as an assist feature, rather than full autonomy.
However, for me, it has been an absolute game changer. It's not just a massive upgrade for driving convenience and reducing motorway fatigue, but the added safety aspects are incredible once you get used to how it behaves.
I’ve just had this adaptive cruise fitted to my t6 Wav by Hazzy Dayz in St Albans along with a multifunction steering wheel aswell I had No buttons and they were brilliant from start to finish and even installed a Dynavin d9 head unit at the same time
Doug and the team were brilliant from start to finish and I’d highly recommend
Completely agree with this. I wasnt sure how good it would be in a manual van, but its bloody brilliant !
How much was the acc to be sorted ? Thanks
How much was the mfsw fitting?
And the adaptive CC from standard CC?.
I paid just over 1k for the steering wheel adaptive cruise and head unit installation and all the hardware and they coded a few extra bits in aswell
I’m in a wheelchair and could not sit around at there workshop so that included coming out to me and installing it all at my house
They couldn’t of been more helpful and really helped me out as I use hand controls the adaptive cruise is a game changer for me
