ACC error / Airbag error HELP!
Kingsimon2000
So I've got 2 warnings on start up.. I've recently installed a radio harness and a 12v power cable through from the battery... going under the matt in the middle to the under the seats... The airbag warning I'm annoyed about as I made sure I didn't unclip or turn the ignition on whilst taking the side panel off... The ACC error is double annoying as I'm going on a 500-mile trip tomorrow. Been using it all week and fine.. But after this first ignition on after fitting the cabling I've got these 2 warnings. ACC is now inactive! any help much appreciated. are all the cabling for the above anything to do with the cables under the seats as I had both of these out to fish cables between the 2. Jason at absolut5 reckons a vcds check might help... anybody with one near Manchester? many thanks. Wife is so f***ed off that I was tinkering with the van!
You can reset with Carista. I did similar except I did turn ignition on when seat was disconnected as I did not know you shouldn't. I bought a Carista and with the 1 free month reset the alarm. £25 all in I think.
Carista at Amazon
