AC Controller T6.1
Knightroturbo
T6.1
Hello all you techies out there. If I change the AC controller from the original one to the one I’ve bought to try and retro fit the heated seats, will the standard buttons (AC & recirc) work without any coding, does anyone know??
No, you will have to do the flap motor adaptions to get it to work properly. You may also get a fault code for heated rear window,
I have just retrofitted climatronic to a T6.1, so I am familiar with it.
Hi Kev, it’s not climatronic it’s just the manual AC so do these flap motors need doing? I’m sure the rear window can be cleared if I get a fault code maybe ??
Don’t forget that unit is actually a control module and sits on the canbus system so depending what age/model/spec vehicle it was taken from some coding changes may need to be made
I would imagine most of the basic functions of that controller will be hard set into it with the firmware so I would expect some of the stuff to work but VCDS will be required to check/change coding, check errors and perform basic settings
Thanks Pauly, guess I need to get it fitted and get someone with VCDS to have a look and see if it will work? The controller is from a 2022 highline model mines 2021 highline.
Hi Folks, anyone able to help me with details of the additional shopping basket items and wiring changes that will be necessary when changing to a climatronic control panel [on a T5.1]? Thanks
