I've had a range of engine fault lights on my T6 204 DSG which appear to be being hard to fix. It is currently having it's fourth stay at the garage.... which is an hour away.
Nov 30th - got the yellow coil light and also lost power whilst on the M4 - I expect this is limp mode as it wouldn't go over 2000 revs. Rang Cardiff VW as that's where I was who were unhelpful and advised VWassist and abandoning my 1 night escape. But by the time I had finished talking to them and restarted the van, the light had gone so I hoped for the best and carried on with my overnight trip to the Brecon Beacons. During this trip when idling in Park the engine kept on over revving.
9th - 15th Dec It then went to the garage twice. The throttle was said to be faulty and replaced and we got it back. 20 miles later the same issue recurred, yellow coil light and back it went. This time something to do with the pins of the throttle cable being an incorrect distance apart....
Late March after not using the van much over the rest of the winter, got the yellow coil light again and limp mode. Again we were recommended to abandon our trip and call vwassist. Back it went to the garage, who couldn't find anything wrong. I insisted that they kept it and drove it about to get the issue to recur. They eventually found something that was "out of range" which was the air intake flap, but that would take a few weeks to get the part in. We were also told that we could carry on driving it & ignore the light.
We have since had a couple of trips in which we have experienced what is now a range of warning lights - the coil, engine management, front assist and ESP. I can't say I have much confidence in it which is hugely disappointing for such an expensive vehicle.
It is currently back at the garage who are also dealing with at least one recall item too. After the various fixes they have noticed that it continues to idle with the revs too high and are now investigating that too. I have very little confidence they have a clue what the underlying problem is... and wonder if this saga will ever end. It's miserable being told on about 50% of your trips in your new van that you should abandon.
Any thoughts?
Any thoughts?
