4motion Suspension Rattle
DaveS76
Hi All,
May have been asked before, but can seem to find this exact issue… van had a Rear inside CV boot replaced last week, ever since have had a very annoying rattle at low speeds and over larger bumps at higher - can also replicate buy jumping in back of van… no obvious things loose, but difficult to assess. Van is running on Bilsten coil overs, no issues before it went into VW for the work. They are claiming nowt wrong, but clearly there is! Anyone had this before so I could lead them to the answer/issue?
thanks in advance!
Dave
I would check the lower shock bolt is tight the B14 have a bad habit of the bushes breaking out so check that the other thing would be the lower spring seat rubber . common issues . fitting a drive shaft normally means disturbing these things
SH
Well, apparently the noise is coming from rear axel… VW need it for a week to investigate $$$.
