30mm Spring And?????
Mr blue
So I’m going to use the 30mm Vw lowering springs is there any thing else I should buy people have mentioned rear cups and drop link arms ?? Advice please :)
If you have the LED lights, watch out for damage to the leveling sensor(s) on the axle when changing things over. VW f*****ed this right up for me. Its easily broken apparently
Just a quick update have had the Vw 30mm lowering springs fitted and are so pleased the ride feels really sturdy and corners better, no more wobbly feeling and looks great lower if your in the market for this I’d say do it
Lowering springs are approx. 20 % stiffer because there is limited travel once lowered so they have to react quicker . unfortunately the standard shocks aren't great with lowering springs . therefore the next thing to buy is a sport shock , Massive improvement and brilliant handling . ( more comfortable as well )
Sport shocks wont change the height at all . I can forward pics of the shocks however if needed
I have DCC and the dealer tells me they will not fit the VW 30mm lower springs - is that right and anyone else heard that?
Hi there , We supply cancellation kits for the DCC £ 280 .00 then you can fit anything you want ??
What does the kit do? Does is disable the DCC ?
It plugs directly into the harness that connects to the shock , It makes the Car management think the original shock is indeed still in the car so no faults get thrown up or warning lights on the dash . Very hi quality German made product .
