2016 VW T6 DSG 4Motion 204 Biturbo Caravelle - losing oil
Pr35t0
Hi - the above van is losing about a litre of oil every 850 miles. No smoke. No leaks. What should I be checking / doing? Cheers.
Not another one :(
How often does it regen? Frequent regens indicates a blocked dpf which in time causes the turbo to fail because of the added pressure.
Have you done a millers oil sample test? If not get one done.
More and more of these 204 cxeb engines fail but sometimes we can be lucky, mine used as much as 1L on 500 miles and then the small turbo failed, after the new turbos have been fitted it’s not asked for any oil in nearly 2500 miles. So it could be a similar thing on yours and the engine might be fine.
The oil sample test on mine looked fine and they couldn’t see any problems with the engine so I think that should be your first port of call.
Not another one :(
Thank you. Appreciate the response. I’ll look into a millers oil sample test. Is it easy to do? What would show up on the test if the engine wasn’t fine?
I’ve had to do several forced regens at a garage due to engine warning lights coming on. I’ve had to replace a filter on the exhaust. Not sure what it was called but it was about £900. I’ve now got a glow plug warning light on and the engine warning light on again and I’m trying to get to the bottom of it all.
