2 Fault codes T6 - Carista
Adam H
Hi Guys,
Got Carista today just for the sake of it to see what shiny things I could enable like the digital Speedo, needle sweep etc.
Not noticed anything wrong with the van, but its showing 2 fault codes. Could anyone give an indication what the problem could be ( I realise one is the rear number plate bulb, tried resetting it but it wouldnt reset ) , didnt want to reset the other one without knowing what it was
Many Thanks
Ah think I've just found what it could be :
" Engine Control Module recently flashed or re-mapped "
Van was remapped last week. Something im ok to ignore or should I speak to Pendle ?
I've had my van re-mapped and have never seen that code, however it is probably best to check with pendle, i'm sure they will see you right.
Do you think it would be ok if I tried to reset the code to see if it just went away ? Or can resetting do something else ?
If it was me i would try deleting it, if it is an actual fault it will return. However i'm no expert. Maybe keep it untill you have spoke to pendle?
Maybe @mmi or @Dellmassive could help? They seem to be pretty clued up with vcds
All sorted guys thank you, my pendle agent replied straight away, told me to reset it as its fairly common and it it wont show again. Which I've done and it has gone :)
