150 6.1 power/boost issue that is fine during regen!
gavinda12
Hi, I have bought a t6.1 150 manual...done over 100k. No lights on dash. It feels very laggy and down on power under 2000 ish rpm then comes on strong....and also you can sometimes hear the turbo spooling up and down under light load at constant throttle. Almost like it doesn't know how much boost to give. Pulling uphill under hard load in 4th,5th,6th around 2000rpm I can feel a very temporary blip in power and a bit of a watergate chatter noise briefly. There's also quite a lot of what sounds like wastegate chatter type noise if you let off after a lot of accelerator input low in the Rev range. Not sure if that's normal/related.
Bizzarely the van drives normally during a regen it seems. Only just done a regen and noticed it feels more normal- not tried it under proper load. . Turbo spools earlier and behaves. Just wondered if anyone had encountered anything similar before I book it in. Boost solenoid? N75?
No other symptoms. No coolant loss.
