Looking for some 10mm spaces hubcentric if possible? Ideally full face fitting
What brands are people using? I cant find anything from H&R
Any links would be greatly appreciated.
@T6Paul as @Pewt has said have a chat with PCD parts. Top quality parts and excellent service. I don’t think they list the 10mm spacer on their website, so worth giving them a call.
I’ve used 15mm on the twin 5 successfully. A 10mm spacer with the twin 5 might be tricky, unless you go for a plain spacer and don’t worry about the central spigot. If you want hub centric spacers, 15mm is the thinnest you can go with the 65.1mm centre bore of the twin 5.
Ideal for fitting bmw wheels with a centre bore of 72.6 to your T5 vans. 2 x 10mm Hub centric alloy wheel spacer. Spacer Thickness : 10mm. Bolts supplied : 45mm Long Thread. 100% Money back policy in place if you are not happy.
