Does anyone have a diagram and part numbers of the engine mounts/gearbox and the bolts? My van is a 2018 dsg highline edition.
Any help would be great!
Just a quick one. Had a lower engine mount fail on a T6 DSG 2018. The garage told me the top one had split as well. So I picked the van up and I am assuming the top one is the one on the drivers side clearly visible. That one had not been changed I can tell as it’s still as it looked...
Have been having a few clunky noises on the van. Seemed to have been getting worse so took a look underneath. Looks like the front engine mount is torn - the one that sits near/under the radiator. The gearbox mount also looks a bit suspect. The engine does seem to shift around quite a bit with a...
Ok so this is hard to explain but i will do my best. I have an early T6 with 5 speed box. its the 102PS thats been remapped to about 170 PS. This was completed around 40k miles ago. it has been all fine.
Recently I have noticed that lets say I am doing 30 in 4th gear and i put my foot flat to...
any one fixed the issue with T6 highline 102 juddering doing about 30mph in 3rd 4th gear I’d just come back from a 30mile journey up the A1 so had a good run. Vans done 4K I’ve done 2k since I’ve had it
