cabin light not turning off
  1. Barley53
    Interior Cabin Lights Won't Switch Off
    Hi, hoping someone can advise. I can't get the interior reading lights to go out when I start the ignition, nor do they come on when I'm about to leave the van (i.e. taking the key out). The lights work fine otherwise and the switch is at the right setting, if I move the switch to the far...
  2. D
    Front Interior Led's Not Turning Off
    Hi There, I have recently upgraded the interior halogen bulbs to LED's but have run into a problem with the cabin interior lights. For some odd reason if they are set to turn on when the door opens, they do but then they don't turn off once the door is closed. You have to manually slide the...
