Which coilovers?
Mikeyg345
Probably been discussed to the death. But has anyone had personal experience with either of these coil overs?
I’ll be fitting to a t32 t6 swb Kombi highline with 245/45/18 wheels
Buy cheap buy twice. I've been in a van with Stance+, the ride is terrible.
If you're going to do it properly do it right, I'm running H&R with the Koni adjustable front inserts absolutely bang on but more spendy.
Thanks. Was that slammed low with big low profile wheels/tires?
I fitted stance then 4 months later fitted H&R totally different you definitely get what you pay for
As others have said. Definitely an area of van modification worth taking sometime and thought to consider before forking out the money. The look may be great and handling round corners on a perfect road surface be good but the slightest bump could be a different story. Had a lower range kit fitted, looked great and got lots of compliments. Ended up getting to the stage tho that you had to shout Brace Brace before any slight bumps. The unexpected ones took everyone by surprise. Had two snapped springs which could not be replaced, so option was buy another kit or go back to OEM. Back to OEM was a big job,lots of ramp time.
