But if the steels are banded, just how wide are they?
It doesn’t add up for me. I run 9” wide 38mm offset on the front and they are pretty much flush with the arch.Hello,
I am just looking at some 19 inch banded steels that are 5 x 122 with a et28 offset.
Obviously I'd need some adaptors to make them fit my 2016 T6.
The adaptors are 20mm would these wheels still fit or would they stick out a lot?
Adapters reduce the offset, they don’t increase it. 20mm adapters will give you an effective 8mm offset.Ok thanks for the advice. I was under the impression adding 20mm adaptors would make it a 48 offset. The amarok 18inch steelies are 45 off set? I was thinking that's only 3mm difference?.
If you really want these wheels then yes, look into those options, I don’t have any experience of either, but someone on here might be able to offer some advice.Right....get you now. Either re drilled hubs or re drill the wheels then.
