KGB listening device?![]()
Nope, no vents.Dessicant pack maybe? does it have any opening or vents?
If it's not VW issue, it must come out.My first action would be to get it open, possibly a remnant from a smuggling trip? ( I am ex Customs and was used to finding objects like that in void spaces. Rental vehicles are commonly used for smuggling). Open it outside in case of dust/contents that could be inhaled. Obviously shouldn't be there and looks as though it was possibly taped in position.
Yes, and besides that, the GPS reception without an external antenna would be less than ideal, so I'll rule out tracker.No holes in it, no wiring to it - it would need a damn good battery to last countless years standalone.
Long term covert trackers can be programmed to send a check-in message home once a day to conserve battery life lasting several years. If your van disappears, you send an instruction to relay the GPS position every hour, minute or second if preferred.No holes in it, no wiring to it - it would need a damn good battery to last countless years standalone.
It is kinda heavy.Long term covert trackers can be programmed to send a check-in message home once a day to conserve battery life lasting several years. If your van disappears, you send an instruction to relay the GPS position every hour, minute or second if preferred.
If it is a tracker, the battery probably takes up half the space in that unit. Bundu, is it relatively heavy for the size?
it could well be. maybe a throwaway oneI'm betting on a tracker
