Warning light on dash after fitting new wheels
andythom188
Electrician
T6 Legend
has any body had the same light come up on the dash in the manual it says it's tyre pressure too low or tyre monitoring system fault
Just push the re set button in the glove box until it Bing's ,it has detected a change in wheel size .
Starline kombi loan van I had it was in the glove box .
Have the new wheels got the tpms sensors on the valves. If not you might have to get these fitted.
Sorry my mistake. Rimstyle website telling me I need them for my van when trying to order.
On a plus, going to save me 160 quid on new wheels..
Mine keeps coming on , but it'll say 'left rear' one day, then after I've reset it, it'll say 'front right' the next time it comes back on! It changes every day. All the tyre pressures are fine, I'm not carrying any more or any less weight each day, I'm assuming it is picking up a fault somewhere??
Any mone had a similar fault??
Im finding if i have any weight in van it comes up with fault on rear right,normally keep it fairly empty
Have you physically checked your pressures then confirmed them as good in your mfd?
Yep no loss of pressure
Same here, its starting to bug me now!!
I will be calling into my local dealer to get it looked into when i get a minute, its interesting that someone else is also having this fault, mine is saying a different tyre every other time it comes on!!
Mine is always right rear, just had a thought that is a newer tyre than all the rest
Had mine come on after fitting new wheels, nearside rear it said, checked pressure and it was 10psi lower than the rest. Inflated it and did the MFD reset and its never come on again after 9000 miles.
I had it once after changing alloys reinflated rechecked reset and all good since
