For Sale VW T6 Sat Nav Full Europe 32GB SD Cards £25 delivered
Pauly
VCDS User
Admin
Moderator
I have for sale some 32GB SD cards for the T6 Discover Media headunit with updated maps
If you have the sat nav head unit and have tried to update the latest maps you will know that the new European maps are too large to fit onto the standard 16GB factory supplied memory cards, if you keep the original card the only option is to drop down to smaller map packs with several map bundles from VW now available that only cover parts of the EU
I am offering new larger cards supplied with the latest/current full European maps preinstalled ready to use
Online retailers are typically charging around £40-£50 each for this which i think is a bit of a rip off hence this offering, im looking for £25 inc delivery which is a stamp on an envelope, if you want tracked/recorded/insured its available at extra cost
(ignore the V21 sticker it has the latest version installed currently V22 but will update as new maps become available)
Please note these cards are only for the T6 2015-2020 with MIB2 discover media headunits, these cards will not work in T6.1 vans with the newer style headunits
They should work with any MIB2 headunit throughout the VW range of cars/vans but specifically are intended for the T6 discover media units pictured below
Apologies for off-topic but, Is this a hidden screen that needs unlocking? Never seen that option on my MY17 T6
Yes there’s a few extra menus/displays that can be accessed like driving school mode or lap timers etc but be warned they are not intended for T6 and most things like that only partially work
I’m not going to get into here but @Robert has done a lot of in depth posts about accessing developer menu/green screen which is the route to this options
View attachment 302232View attachment 302233
Hello Pauly
Did you have any of the latest SD cards as mentioned above.
Andy
