VW supplies Westfalia tow hitch issue
LondonLad
Anyone else had an issue where the rotating handle will not rotate to go back against tow hitch?
The metal section showing by the red & green stickers should close up when I rotate it, which it normally does but for some reason got stuck in this position, after I removed the tow hitch from the van 🤷‍♂️
One of the ball bearings is stuck out just needs a little tap with the shaft of a hammer to knock it back slightly. Once they're all in sat properly the tension on the hadle will be released and it'll spin back into place .
Keep your fingers away from the handle when you do it .
Either that or wind the tension on a tad with the handle and push all the bearings in at the same time .
mine is the same, as you say just a small tap with hammer
