VW Service Actions
Loz
Moderator
VW Service Actions
23Z7
AdBlue software upgrade to deliver correct amounts of DEF during regeneration.
57H5 Due to inadequate sealing, water may penetrate into the Bowden cables in the driver’s or front passenger’s door and impair the movement of the cable’s inner wire at temperatures below the freezing point.
As a result, the doors may open inadvertently, increasing the risk of an accident.
The Volkswagen T6 models affected by this recall were manufactured between 1 July 2019 and 25 February 2020.
58D8 The electrical child safety device may not be mechanically locked even though it has been activated by the driver and the permanent indicator on the button indicates normal operation with no indication of a fault.
The Volkswagen T6 models affected by this recall were manufactured between 27 September and 8 November 2019.
58D7 If the vehicle is washed with a high-pressure cleaner, water may enter the interior, damage the control device for the tailgate and cause an incomplete short circuit with localised damage from scorching. When air enters through open windows, doors, or the sliding roof, the damage from scorching can develop into a fire.
The VW T6 Multivan / Transporter models (with an electric tailgate and an electric sliding door) affected by this recall were manufactured between 23. 7. 2015 – 8. 2. 2019.
75A1 Tape applied to edges of California pop roof to stop corrosion from edge seal.
26L5 Replace faulty Differential Pressure sensor that can cause the DPF to not regenerate.
23U8 Software update for CXEB ECU
Feel free to add new and missing service actions CODE and description below and a moderator will update this post. These can often be found on the invoice paperwork.
