Vanshades question
Cupotea
Hi all,
I've recently had some Vanshades fitted to my kombi sliding doors and I'm not sure they're 100% right. Should they be flush all around? I'm a little concerned the door seal won't be tight against the metal and allow water ingress.
Cheers,
Pete
Hi - Did you ever get an answer about this? Just installed mine and was wondering the same thing
That pod looks like it’s on back to front. The side facing inwards should be flat all the way across with the blind housing nearest the glass
Mine protrude and I’ve never had an issue with water ingress… not from the door seal anyway.
They can only be fitted one way too!
I think the oem Kombi window vanshades are deeper to allow for the window to come forward when opened,the handles also protrude forwards to open
