rand new bought at the end of February 2026, was put up once at easter and had to go to Vango to be checked as it wouldnt inflate correctly.
Its now fully repaired and checked by Vango.
The spec:
The Quadris is a versatile AirBeam® drive away awning designed for comfort, flexibility, and year-round adventure. With its spacious height and open-plan layout, it’s perfect for socialising or relaxing after a day’s exploring. Three large window panels let you enjoy the view while staying protected from wind and rain, or fully open them to embrace warm, sunny days.
Made with durable Sentinel Active 150D fabric, it offers a strong, waterproof (4000mmHH) shelter that stands up to the elements. Whether the weather turns or the sun shines, The Quadris adapts with you—ideal for campervan travellers who want more from their pitch.
Dimensions:
What it looks like (note these are from Vango until tomorrow when I get better pictures).
Quadris Air Low
The
Vango Quadris Air Low Driveaway Awning
is a square-shaped, inflatable touring awning designed specifically for campervans and low-roofed vehicles.
YouTube·Outabout +1
Key Technical Specifications
FeatureSpecification
Main Awning Dimensions280 cm (Length) x 280 cm (Width)
Connecting Tunnel Depth80 cm (Total length including tunnel is 360 cm)
Internal Height225 cm
Vehicle Connection HeightLow variant: 180 cm – 210 cm
Connection Width240 cm
Kador Rail Length260 cm
Total Weight18.1 kg (Total bag weight approx. 18.7 kg)
Pack Size75 cm x 40 cm x 40 cm
Pitching TimeApproximately 8 minutes
Fabric & Weather Protection
Structure & Assembly
Design & Connectivity
Located in Kirkby in Ashfield close to J28 off the M1.
The list price from Vango is £675.00 which is what we paid from LeisureShop Direct.
I am looking for £600.00 as its brand new.
Viewing welcomed.
Collection preferred but courier via DPD is a possibility.
The spec:
Dimensions:
Quadris Air Low
The
- Main Material: Built using Sentinel Active 150D Polyester fabric (110g/m²), balancing a light pack weight with durable touring performance.
- Waterproofing: Features a 4,000 mm Hydrostatic Head (HH) rating for reliable rain protection.
- Colour Preservation: Utilises ColourLok Eco™ technology, which enhances UV protection and maintains color retention over time.
- Groundsheet: Fully sewn-in Polyethylene groundsheet featuring a drop-down flat entry at the doors to prevent tripping.
Outdoor World Direct +2
- Inflatable Frame: Uses Vango's AirBeam® technology with a single inflation point system for rapid setup.
- AirSpeed® Valves: Designed for effortless inflation and rapid deflation.
- Pre-angled Beams: Maximises head room and side-wall usability while providing better structural bracing against high winds.
- Stability Support: Includes Vango's TBS® II Tension Band System to remain stable during adverse weather conditions.
- Drive-Away Freedom: Freestanding structure allows you to roll away and toggle the connecting tunnel to drive your vehicle away for day trips.
- Multi-Fix Attachment: Features pre-attached 6mm kador beading, 8-metre over-vehicle straps, roof bar tabs, and a sleeve for a pole-and-clamp kit.
- Gazebo Mode Flexibility: All three outward-facing panels can be rolled away fully to change the awning into an open gazebo.
- Access Points: Two doors built directly into the connecting tunnel allow easy entry to the front or back of your vehicle without passing through the main awning living area.
- Interior Elements: Outfitted with Diamond Clear windows featuring privacy curtains, SkyTrack® II hanging tracking for lights/organisers, and mesh screens on the front door.
Viewing welcomed.
