For sale: My Vango Galli II Low driveaway awning - used only twice!!
Collection from South East Wales
£450
Awning includes full bundle:
Galli II awning
Carpet
2 inner bedroom tents
Footprint
Skyliner (optional internal liner)
6mm to 6mm drive away kit to use with van mounted awning rail
Vango Airpump (one side of foot broken, which doesn’t affect use)
Repair kit
Thermal screens from Fuel Lagoon:
The screens have 5 layers, 2 layers of foil and 2 layers of bubble insulation to reflect and trap the heat or cold then 1 layer of soft fleece on the inner side to keep you cosy when camping. Windscreen, 4x Side windows, Tailgate
Description from Vango
Three words express the very essence of the Galli II: innovative, contemporary and versatile.
The Galli II includes skylight windows, allowing stargazing at night and a bright living area during the day. On top of this, the new AirZone system enhances the circulation of air within the awning, reducing the chances of condensation.
There is even the option to add in one or two inner bedrooms to offer dedicated sleeping space at the rear, ideal for large families or groups of friends. Flexibility is key in a drive away inflatable awning and to enhance this, there are 2 side doors in the connecting section between the awning and your vehicle, creating a great “utility room” for storage that will help your space stay clean and dry. The Galli II brings a fresh approach to drive away awnings.
Full details for Vango Galli II
£450
Galli II awning
Carpet
Footprint
Repair kit
- Vango AirAway® Structure - Inflatable AirBeam® technology allows for pole free pitching and easy erection on your vehicle (double action pump included)
- Sentinel Pro 420 Fabric - Featuring 420 denier double ripstop threads, our Sentinel Pro fabric has superior strength and long-lasting durability, combined with PU technical coatings make Sentinel Pro exceptional in terms of waterproofness.
- Oxford polyester groundsheet - The perfect balance between low weight and high durability
- Fully Sewn-in Groundsheet - Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment
- AirSpeed® Valve - Simple system with easy access positioning to inflate your AirBeams® with even less effort
- Pre-angled beams - Achieve greater internal space than with a standard curve. Provides effective bracing against winds
- SuperBeams™ - Larger diameter beams provide additional structure and stability to the awning.
- Patented Vango TBS®II Tension Band System ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the pole at 3 points, and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
- Touch fastener roof bar attachment tabs - Simply wrap around vehicle roof bars for quick and easy use
- Pole & Clamp kit sleeve - Allows optional pole & clamp kit attachment, for vehicles without a kador rail yet obtain a gutter
- 8m Straps included - Straps can be tensioned and rested over the vehicle, allowing the awning to attach to vehicles without kador rails
- Webbing storm straps - Provides secure guying at the front and rear of the awning
- Line-Lok guyline runners - Lock securely, simple to release and high performance in all conditions
- Reflective webbing - Picks up torchlight so the pegging points are easily spotted in low light conditions
- Large windows - Provide bright and airy environment
- Diamond Clear windows - Maximise light and visibility
- Zipped privacy curtains - Simple and quick to use, zip curtains allow varying levels of opening or simply roll down and secure away.
- Flat entry - Easy access for wheelchairs, prams and people with reduced mobility
- Roll away rear porch - Can be rolled away when not in use
- Vango AirZone - Ventilation panels create a comfortable flow of air through the awning which significantly reduces condensation
- Fully taped seams - All flysheet and groundsheet seams are factory taped which provides a watertight seal
- Wide mouthed bag with compression straps - Allows your awning to be packed away and carried to and from the campsite easily
- Optional bedroom inner - Optional extra available to purchase separately
- Steel rock pegs and mallet included - Pegs are strong, durable and can be used on more challenging terrain
- AirBeam® Pump Included - Double action pump that will rapidly inflate your AirAway® Awning which comes complete with a pressure dial
- Cable entry point with tidies - Zipped entry point for power cable, with touch fastener tidies
- Lantern Hanging Points - Conveniently positioned to attach your light(s)
- Fire retardant fabrics - Meets European EN5912 safety standard
- Fully wind and rain tested - Weather tested to the European standard EN5912 by certified test centre
- External doors in connecting panel - 2 external doors at each side of connecting panel for convenient access to and from your awning
- Ventilation system - Larger vents increases air flow and significantly reduces condensation
- SkyTrack II® - A flexible hanging system which allows you to easily attach lighting, storage or our new SkyLiners. The SkyTrack system truly allows you to design your tent to suit your needs
- Orange reflective guylines with tidies - High visibility lower half to prevent hazards and ensure stability in high winds
- Skylight Windows - Windows which run along the roof line of the awning to enhance light during the day and for star gazing at night.
- Over vehicle webbing straps - Can be tensioned and rested over the vehicle, allowing the awning to attach to vehicles without kador rails
