Tyre pressure warning
Captain Mainwaring
A couple of days ago the orange tyre pressure warning light came on, and the MFD told me I had lost tyre pressure, get them sorted then reset. These still come up every time the ignition is switched on. The tyre pressures are all fine so I presume some kind of fault. Anyone else had this and how do I reset it? Apologies if this is a case of I should just RTFM
Can't you just reset it in the MFD menu and see if it comes on again.
It's in the mfd menu, go into the tyre pressure bit and click on save and it resets the system and stores the current pressure
