It’s cause you put them MA ones on not VWHi all,
Any ideas how to get these off? Gone to check pressure and 3 of the 4 are stuck tight. Cheers
View attachment 112217View attachment 112218
why not just apply some WD40 or similar, then visit your local independent tyre seller at the earliest opportunity. If they rip the valve out you're in the right place to get it fixed. They probably see it all the time and have a technique for removal.Probably call VW assist, don’t want to bugger the thread or the alloy... what a thing to call them for!!!
They were vw ones from dealership...It’s cause you put them MA ones on not VW
Was very careful with them. AA is here with a hacksaw blade...If you have used grips on the valve stem, they can no longer be trusted.
A trip to the tyre dealer for new valves..
Happened to me so never use metal caps anymore.
With these types of caps it’s best to apply a small amount of grease before fitting.
I always find with metal dust caps it’s best to throw them in the bin, pain in the arse at least the tyre was not flatThey were vw ones from dealership...
I think that went over some headsIt’s cause you put them MA ones on not VW
I know I’m used to itI think that went over some heads
