So the story is….Soon after taking delivery of the van from new with factory fitted tpms I took it to Bognor Motors for some upgrades and mods, the wheels being one of them. Off with the standard Devonports and on with 17” Black Rhino Arsenals ( supplied by me) and General Grabber 235/65 x 17 supplied and fitted by Bmvs when they also swapped over the tpms valves to the new wheels and set up the new pressures into the tpms appropriate for this set up. ( in hindsight I should of checked what pressures they should of been set at as they set them far too high…in fact higher then the recommended max pressure of the tyre ( front 57psi rear 48) which is apparently what they were told at the time.)
This only came to light recently on another thread on here, Swamper tyre pressures I think.
Last year a fault came up on the tpms with the nsf wheel not registering, so I made the journey down to Bognor and they duly fitted a new sensor valve and reset the tpms, still with the pressures far too high.
A few months ago the same tpms sensor threw a wobbly and again wouldn’t register. So I thought this time I’ll take it to my local dealer who can replace the faulty tpms sensor under warranty and code in the ‘new’ lower pressures….or so I was hoping!
Duly dropped van off and soon after the dealer called to say they had swapped the front wheels over and the fault still registered as nsf… so not the sensor grrrr….. they could not investigate any further without fitting the original wheel/ tyre combo and tpms valves as their system could not accommodate the size of tyre fitted to the aftermarket wheels now on the van..ffs!
So appointment made with a cost of £72 per set x 2 to be swapped over and checked. The clock is ticking as the van warranty runs out the end of June which is when the mot is due. I know the fault is now logged with Vw but it’s just getting to the bottom of it and getting the mot done which I’m getting a bit nervous about.
The word ‘ module’ has been mentioned a few times.
