2010 T5.1
I have recently converted my 7 pin towbar socket to 13 pin to enable me to tow a new caravan, before now I have only towed trailers with convention tungsten lighting.
With the caravan now hooked up, the van will show a lamp failure warning on the dash, my guess this is almost certainly due to the LED lighting on the caravan.
I assume others have had the same issue and wonder what they have done to overcome the problem.
I guess you could add a resistor to each of the affected circuits within the caravan, but in my mine this is just adding unnecessary load and generating heat.
