T6 2018 Rear Heating problem
ssebbthewall
Hi!
Vin "WV2ZZZ7HZJH154672"
I have a 2018 T6 5 seater with "heat pack" in the rear.
I discovered that there is only cold air blowing. I checked the valve is moving correctly when switching heat/cold.
I changed the radiator this autumn and have run the bleeding process several times.
I think there might be some air stuck in the rear even though i have run the bleeding program.. Anyone have had the same problem??
Thanks.. :)
