T6.1 head unit upgrade options - Any problems with the Discover Media?
Background: My T6.1 head unit (lowest spec) has had issues with the sound quality when using iTunes with the phone plugged into the USB-C sockets. It is fine when using Bluetooth - however I cant use sat nav then.
I have now given up hope of VW ever sorting this issue.
So, thinking about my options.
1. Get the next level up head unit retrofitted (Discover Media Pro?) with the 8" screen. If you have this head unit does it suffer from the same poor sound quality using iTunes in car play? Can I used sat nav and iTunes over Bluetooth?
2. Get the even larger 9" screen unit fitted. Same questions about usability as the 8" screen.
3. Get an Alpine Halo 9 or 11" screen. Does everything work as OEM in the T6.1.
Thanks for any input.
I have the basic version and everyone who speaks to me on the hands free says the quality of the call is dogshit. I’ve been told it’s the head unit, I have got the 8 inch upgrade just waiting to get it fitted as told even after buying the unit etc I still needed Around 500 to fit. I’m not sure whether to sell up and go to the 9inch instead or try the ‘pluscenter’ head unit. I’m all for genuine really but when parked up wouldn’t mind using the screen with full potential to mirrror the phone etc
Go for the 8” version. The 9.2” has no volume knob which is annoying, has buttons in the unit instead. Wish I had gone 8” instead if 9.2”. It’s not significantly bigger.
Is the volume knob used for anything else? I never actually use the volume knob on my basic unit as I always use the steering wheel buttons.
I had the Discover Pro fitted by @Dav-Tec It looks so much better than aftermarket. It's been faultless since fitting. Love the sleek look and no buttons. Like you I use the steering wheel for most things so doesn't bother me at all. Coupled with the virtual cockpit it's great.1000011648.jpg1000011663.jpg
I always use the volume knob, hardly use the steering wheel for it, dunno why, just a habit
I have the discover Media, which is better than the first 6.1 I had that had the basic , but it’s not with out its issues, firstly it will play fine for days then there will be no sound , the only way to get it back is a reset, also when I finish a call on CarPlay, CarPlay then decides to reboot itself, a bit annoying, it’s been updated
If it goes wrong I will definitely fit a halo, like we do weekly for owners , far better sound quality,
Do you think the issues you have with the Discover unit are very rare, or quite common? I’ve not read many complaints about it.
How much better is the sound from the Halo 9 / 11 than OEM?
I’d prefer the look of OEM rather than the floating screen.
I believe there are 2 or 3 differnt versions (read manufacturers) for each version of the OEM units. Are any better (less problematic) than the others?
@Dav-Tec @Absolut5
@Dav-Tec @Absolut5
No I wouldn’t say rare as getting more owners contacting us with issues.
There is no comparison between the sound quality of OEM over the Alpine, cleaner signal, more powerful and infinite sound adjustments
Hi. Can you explain this a little? I installed MIB3 on T6.1, with all services unlocked, but I don't have a GPS signal. Apparently, I need to install the SOS module on the high version.
Apparently you need to swap the SOS module for a highline version. You still get a red flashing light on the SOS module (unless some ‘firmware’ is flashed onto the module to update it).
When I was swapped to MIB3 they did swap the SOS unit as well
I found a used T6.1 module, but I'm not sure if it's possible to adapt it to my car or if I need to buy a new one. I'm also not sure if it's possible to upgrade the SOS to a high-end version, as a low-end module was registered in VW manufacturing. I imagine that component protection will be included in the second-hand SOS module.
