Solow / Accuair Air Suspension replacement parts
Booger70
Hi,
I have a T6 T32 that has SoLow / Accuair eLevel + suspension fitted for the previous owner by Chris at The Van Cave.
The rear right lower sensor bracket has become damaged and bent and as such has damaged the sensor arm.
I messaged THQ re the bracket and apparently they only have the full set for sale rather than the individual bracket.
As Chris is no longer trading does anyone know where I can get the single bracket and also the best place to get a replacement sensor arm?
Thanks in advance
Ian
Hi,
Thanks in advance
Ian
Try Chris at lowdown transporter , he may have one floating about
Chris usually got his brackets from PLUSH so explain to them and they may help.
If you want, put a picture of your van up and i'll give him a call and see exactly which ones he used......i'm sure he will remember when he sees your van :thumbsup:
Thanks @Pewt, Chris changed the same bracket on the near side last year and at the time said it was a shame it wasn’t the o/s as he had loads of those as the vans with LED lights didn’t need the additional bracket as he used the light levelling bracket.
Was able to order the single bracket from Plush as well as a single sensor arm to replace the cracked one. Thanks again @Pewt
