I am an idiot so have one of these for sale because I was impatient - they RRP for £379
It has no original box and has a small scratch on the grille (see pic) - they face down so not visible when fitted - £240 inc insured P&P
Less than a month old, sound fantastic, working perfectly, ready to install…
You need an amplifier (not supplied) to power this.
Here are the specifications:
Audison Prima was designed to meet the interest of the car model enthusiasts who like to appreciate all the nuances of the musical message with components that are perfectly integrated in the car OEM system, preserving the most precious Prima on Audison requirement of OEM integration: space.
- Ultra-low profile (5.6 in. / 142 mm) box with a sealed design perfectly tuned to fully exploit the APS 10 D driver.
- 2 Sides/2 Sounds: design provides the ability to choose between
- Down-Firing mounting to increase the low-frequency extension and
- Up-Firing installation to obtain more punch and definition.
- Leveling feet with velcro inserts included for a secure grip on the carpet while maintaining easy removal.
- SSP (Sub Smart Plug) features both traditional push contacts and a
- Plug-&-Play terminal block to easily configure the impedance as
- required and provides a quick release.
- Rounded corners allow easy positioning in the trunk and act as reinforcement to reduce enclosure resonance.
- 6 Special designed cone-dustcap-basket geometry which guarantees a
- long linear excursion capability (11 mm, one-way).
- Massive driver motor assembly, optimized with FEM (Finite Element
- Modeling) for perfect control under high excursion conditions.
- Water-repellent pressed paper 10 in. cone, featuring a profile developed with FEM simulation and optimized with the Klippel Scan Vibrometer.
- Specifically developed to be combined with either the AP8.9 bit
- (2 CH + 2 CH bridged), AP5.9 bit (Sub CH) or AP4.9 bit/AP4 D
- (2 CH bridged) amplifiers taking advantage of the bass boost feature and integrated parametric equalizer of the built-in DSP.
- A sturdy metal grid is included for the total protection of the subwoofer driver.
SPECIFICATION
- Size 250 mm
- Power Handling - Peak 800 W
- Power Handling - Continuous 400 W
- Magnet Material HIGH DENSITY FLUX FERRITE
- Cone Material WATER REPELLENT PRESSED PAPER
- Dimension A 470 mm
- Dimension B 334 mm
- Dimension C 120 mm
WHATS INCLUDED
- APBX 10 DS
- Velcro Feet
- Speaker Plug
- Booklet
