Solar vs More / Better Batteries vs Powerbank
Huba
Hi,
Currently I have a 100ah LB charged via ctek 230se.
Our power usage is lights, USB charging, diesel heater. We run a 12v cheap coolbox that we only run when driving or on hook up. We would probably like to get a compressor fridge box in future ideally
It's all working fine off ehu, but looking at site prices the cost for ehu is rising and we now have a dog so are likely to be on sites for 3-4 days rather than 1-2. So I'm worried about the battery depleting
My first thought was put 200w solar panel on roof (plus solar controller because of ctek limitation), but then I read solar is pretty much useless in winter and I'm going away in van end of November for a few days off a ehu, I'll be running the heater and worried it will deplete the battery
Next thought was a powerbank, but these seem quite expensive and not sure how to integrate
Then I thought my lesuire battery is a couple of years old, maybe just replace with a lithium one.
Then I thought could I just add a second AGM battery to save money. My current battery is under seat so might be hard to integrate.
Any advice to the best / cheapest way forward? Having written the above maybe using ehu in winter and getting a solar panel for rest of year is best?
Thbaks in advance
Looks like you have done your research as you have detailed you're options above.
Id go down the lithium upgrade route, and add the solar panel too.....
They will work with bright daylight, just not very effective.
More info here:
