Smev 211 Wattage Question
Jean-Louis Bourdon
Firmware Engineer
Hi,
I've ordered an EVO kit which has the oven space planned in
i'll go get some cabling finished when i put the furniture kit together
I need to get an extra cable for the oven compared to what's already there (fridge and accessories)
the SMEV 211 i'll get just says just "Electronic 12-volt ignition with safety ignition system"
what is the wattage required? i searched both forum and specs online
has anyone got a manual? and could upload a photo?
thanks
online FO211FGT manual says:
This chapter refers only to models with the wording 12 V
appliance.
THIS APPLIANCE MUST BE CONNECTED TO A 12 V
CIRCUIT MUST BE FITTED WITH A SAFETY FUSE NOT HIGHER THAN 3 AMP.
WHEN WIRING THE APPLIANCE RESPECT CORRECT POLARITY!
IT IS OF UTMOST IMPORTANCE NEVER TO CONNECT THIS APPLIANCE TO MAINS
VOLTAGE (230 V∼) WHICH IRREVERSIBLY DAMAGES APPLIANCE COMPONENTS
AND CREATES A HAZARD TO THE USER.
To connect the appliance use a 1.5 mm double red and black wire and wire to the terminal junction box located at the
rear of the appliance. The red terminal is the positive pole and the black terminal is the negative pole.
FIXTURE
THIS APPLIANCE MUST BE FITTED AND SECURED TO THE CABINET UTILISING FIXTURE SCREWS AS
ILLUSTRATED IN FIG. 5 – PG. 128.
